Pressure get decrease in result
    • baeblue321
      Hi, well I have simulation a blade that the inlet's boundary condition is Pressure Inlet and the outlet is Mass Flow. But the problem is in my boundary condition I put the pressure in Gauge Total Pressure is 96483 Pa but when i saw in the result the pressure inlet is getting decrease (72830 Pa). anybody know why my pressure inlet didn't lock into 96483 ? I really need ur help. Thanks
    • Karthik Remella
      Administrator
      Is your flow incompressible or compressible? And, are you observing a dip in the static pressure value (72830 Pa)?
      Thanks.
      Karthik
    • baeblue321
      its a compressible and actually the fluid is a steam. I'm curios why the inlet fluid is changed while i set in the pressure inlet. Is it possible if the problem was because i used the material is air? because i still cant decide what fluid i used if the fluid is steam
    • Karthik Remella
      Administrator
      If your fluid is steam, please use the properties of steam. I'm assuming that the velocity of the fluid is high and therefore, the flow is compressible. Is that correct?
      Thanks.
      Karthik
    • baeblue321
      sorry, i was wrong the fluid actually a gas that contain a little SO2, the velocity for one blade i assume around 26,5 m/s  and the yes the flow is compressible. I put the air as material fluid cause i assume both of gas and air same, correct me if i was wrong
    • baeblue321
      here  is what i mean about the different
    • Karthik Remella
      Administrator
      Could you please perform the same using the variable 'Total Pressure' and not 'Pressure'? Are you getting a value which is closer?
      Thanks.
      Karthik
    • baeblue321
      The option for pressure only Pressure
      Click on the button with the ... next to "Pressure".
Viewing 8 reply threads
  • The topic ‘Pressure get decrease in result’ is closed to new replies.
