January 14, 2026 at 12:36 am
ssufi
SubscriberWe have been running simulations for surface discharge in EMA3D with step size (internal time steps) of 5e-13s. However, as we increase the total time steps (number of internal time steps), the simulation time and the result file size increases. We tried using higher step size (larger than 5e-13s) but it gives incorrect result.Â
- Is there any way to reduce the result (.h5) file size by removing unnecessary data (it calculates about 30 different properties, we only use 3/4.)?Â
- Is there any way to extract the data only for a certain section of simulation (50000 to 100000 steps of a 100000 total steps simulation) from the .h5 result file?
- Is there any way to reduce the simulation time other than reducing mesh or total time steps?
Thank you!
Suaib
Viewing 0 reply threads
1885
1403
1267
