RGP file for fluent
    • rahul159753159
      I have created a predefined mixture of fluid in refprop (Version 10.0) to be used in fluent (Version 2025R2). I have the mass fractions and all the .fld files that refprop is using to create the predefined mixture. I don't really know how to create RGP for that. I looked out for this thread How to generate and setup RGP-Tables for CFX multiphase flow simulations but the zip file seems tp be removed/missing. Can anyone help me with this please?
      Thanks
    • SRP
      You can check user's manual for creating RGP file: 6.1. Real Gas Property (RGP) Table Files
    • jcooper
      Hi Rahul:
      The generic process for creating RGP files uses the ANSYS System coupling application. You supply a Python file with instructions for the mixture and then run from the command line:
      "C:\Program Files\ANSYS Inc\v251\SystemCoupling\bin\systemcoupling" -R script.py
      The resulting RGP file can be used with either CFX or Fluent.
      Below is a sample script for a mixture:
      import os
      import pyExt.RefProp as arp
      fluidsPath = arp.getFluidsPath()
      mat = arp.RefPropLib()
      # Enter mixture components - these all must exist in the material database
      fluidList = arp.FluidList()
      fluidList.append("R23.FLD")
      fluidList.append("R116.FLD")
      # Enter mass ratios of mixture components
      composition = arp.Values()
      composition.append(0.46)
      composition.append(0.54)
      matInfo = mat.setmix(fluidsPath, fluidList, composition)
      mixInfo = mat.info()
      print(
          f"Critical point       : (",
          mixInfo.tempCrit,
          mixInfo.presCrit,
          mixInfo.rhoCrit,
      print(
          f"Cricondenbar point   : (",
          mixInfo.psatMaxT,
          mixInfo.psatMax,
          mixInfo.psatMaxD,
      print(
          f"Cricondentherm point : (",
          mixInfo.tsatMax,
          mixInfo.tsatMaxP,
          mixInfo.tsatMaxD,
      #Set the variable interpError as follows to define an accuracy, may need to adjust
      # for convergence
      #'low' :       1e-3
      #'medium':     1e-4
      #'med-high' :  5e-5
      #'high' :      2e-5
      #'very-high' : 1e-5
      interpError = 5.0e-5
      #Set table ranges larger than problem range to allow for overshoots
      Tmin = 200.0
      Tmax = 500.0
      Pmin = 3000
      Pmax = 2.4e06
      # generate tables - pass arp.ADAPT_AUTO_TP for 1D tables and arp.ADAPT_AUTO_2D for 2D
      R508BL = arp.RGPLiquid("R508BL", Tmin, Tmax, Pmin, Pmax, interpError, arp.ADAPT_AUTO_TP)
      liquid_tab = arp.buildRGPComponent(R508BL)
      arp.writeRGPfile("R508BL.rgp", liquid_tab)
      R508BV = arp.RGPVapor("R508BV", Tmin, Tmax, Pmin, Pmax, interpError, arp.ADAPT_AUTO_TP)
      vapor_tab = arp.buildRGPComponent(R508BV)
      arp.writeRGPfile("R508BV.rgp", vapor_tab)
      mat.release()
