December 3, 2025 at 4:29 pm
sacharin1993
SubscriberI have been simulating flow around a circular cylinder (in both 2D and 3D) using ANSYS Fluent, but I am consistently obtaining drag coefficient values (Cd) that are too low.
I have tried several approaches, including:
• Using a high-quality mesh
• Targeting both a y-plus value of between 0.3 or higher but less than 1
• Running both steady and transient simulations
• Using the k-omega SST turbulence modelI am trying to match experimental Cd values, which are typically around 1.2 for Reynolds numbers between 1×10^4 and 1×10^5. I was able to reproduce these results previously using OpenFOAM.
However, my Fluent simulations are giving me:
• Cd ≈ 0.9 for Re = 1×10^4
• Cd ≈ 0.7 for Re = 1×10^5These values are significantly lower than expected.
Has anyone been able to obtain closer values and how?
Thanks
December 3, 2025 at 5:31 pm
Essence
Ansys EmployeeHello,
Did you check the Reference Values?
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v252/en/flu_ug/flu_ug_ReferenceValues.html?
December 4, 2025 at 2:21 pm
December 4, 2025 at 3:01 pm
December 4, 2025 at 3:42 pm
sacharin1993
SubscriberI am calculating correctly the Cd, but the results do not agree with experimental (standard) data and I would like to improve the results to get closer to them.
December 4, 2025 at 4:09 pm
Essence
Ansys EmployeeCould you please share the screenshot of the reference values you are using?
December 10, 2025 at 8:59 pm
sacharin1993
SubscriberThis screenshot shows the reference values used in the simulation.
The simulation concerns flow past a circular cylinder with a diameter of 0.1 m, placed inside a parallelogram-shaped enclosure. The width of both the enclosure and the cylinder domain is 0.2 m. The enclosure has a length of 4 m and a height of 2 m, and the cylinder is located 1 m downstream of the inlet.The simulation was performed in 3D using both steady and transient approaches. The maximum y+y^+y+ value was 0.6, and the mesh consisted of approximately 10,000,000 cells. At Re=2×104Re = 2 \times 10^4Re=2×104, the resulting drag coefficient was Cd=0.805C_d = 0.805Cd​=0.805.
Additional mesh refinement did not change the results. I also increased the depth of the cylinder and enclosure from 0.2 m to 0.5 m, but no variation in the drag coefficient was observed.
December 10, 2025 at 9:00 pm
5614
1885
1403
1298
