November 12, 2025 at 8:19 am
yuka.kusama.9t
Subscriber【Difference between
CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK(Option 1) andTIED_SURFACE_TO_SURFACE】The analysis results differ between a model joined with
CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK(Option 1) and a model joined withTIED_SURFACE_TO_SURFACE.What is the difference between
CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK(Option 1) andTIED_SURFACE_TO_SURFACE?CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK(Option 1) is described as follows:
Eq. 1: Tracked nodes that are in contact, or that subsequently come into contact, will permanently stick; tangential motion is inhibited.For reference, the results from
TIED_SURFACE_TO_SURFACEmatch those from a model with node sharing.【CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK(OPTION1)とTIED_SURFACE_TO_SURFACEの違い】
CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK(OPTION1)で結合したモデルとTIED_SURFACE_TO_SURFACEで結合したモデルで解析結果が異なります.
CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK(OPTION1)とTIED_SURFACE_TO_SURFACEでは何が異なるのでしょうか.
CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAKのOPTION1は以下のような内容です.
EQ.1: 接触したスレーブ節点はそれ以降固着します.接線方向の動きも許されません.
ちなみに,TIED_SURFACE_TO_SURFACEで結合したモデルの解析結果と,節点共有で結合したモデルの解析結果は同じでした.
よろしくお願いします.
November 13, 2025 at 1:24 pm
Satvik
Ansys EmployeeHello User,
- TIED_SURFACE_TO_SURFACE enforces a permanent, unbreakable tie with no sliding or separation, suitable for rigid or welded connections.
- CONTACT_AUTOMATIC_SURFACE_TO_SURFACE_TIEBREAK allows for initial tying but enables failure and subsequent sliding/separation, making it ideal for modeling debonding or adhesive failure.
- Tiebreak contacts use penalty-based formulations and require careful definition of failure criteria, while tied contacts are constraint-based and do not allow for failure.
- このトピックに返信するには、ログインする必要があります。
4823
1587
1386
1242
