October 27, 2025 at 5:15 pm
javat33489
Subscriber -
October 28, 2025 at 1:48 pm
Ram Gopisetti
Ansys EmployeeHi,Â
I don’t believe this issue is related to contact. However, you can try increasing the stiffness parameters using SFSA and SFSB. It is also advisable to set the STRETCH value in SECTION_SPG to 1.01 when modeling with materials mat72, mat84, mat96, mat111, mat159, mat272, and mat273. Adjust this value as necessary, followed by fine-tuning the FS parameter.
Additionally, set the Dilation parameter to 1.6, KERNAL to 2, SMSTEP to 30, and IDAM to 1.
For improved evaluation of the model, it is recommended to render the SPG mesh as particles, which provides a clearer visual assessment of the cross-section.
Cheers, RamÂ
October 28, 2025 at 5:19 pm
javat33489
SubscriberThanks sir I'll try!
October 28, 2025 at 5:34 pm
October 28, 2025 at 6:04 pm
October 30, 2025 at 3:40 am
Dennis Chen
SubscriberI am relatively sure you need a much higher density of particles.  You can check the documentation/literature for more detail about how the particle sees each other.  I am not going to say more because I am by no means an expert on SPG but I think it's smart just to do some mesh sensitivity studies.Â
5824
1305
