October 27, 2025 at 4:51 pm
Sergio Blanco
SubscriberDear all,
I am trying to build a volume model from stl images I've got from segmentation. I have the three layers of my domain (internal blood, middle interal wall and external wall). You can see the photo. I need to build a model with two volumes (one defined by the inner and middle surface and the other defined by the middle and outer surface). I am not able to build the volumes (it seems I am not able to build a closed contour defined by surfaces). I am using Ansys Discovery. The three surfaces are patch bodies I have built from the faceted stl images.
Any help about the procedure, or any link to a video will be much appreciated.
Best regards,
Sergio
Viewing 0 reply threads
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
1487
1338
1188
