October 10, 2025 at 11:41 am
2258980816t
SubscriberHow can I make the magnetization direction of a permanent magnet rotate with the coordinate axis during a parametric sweep in Maxwell’s static magnetic field simulation? Thanks~
October 10, 2025 at 1:39 pm
MirandaH
Ansys EmployeeHi, you can assign object coordinate system on the object.
October 11, 2025 at 2:32 am
2258980816t
SubscriberDear MirandaH,
I’m very glad to see your reply. However, we’re still encountering some issues on our side.
I’m using Ansys Electronics Desktop 2021 R2, and according to your instructions, I’m unable to perform a parameterized coordinate rotation in this version-
October 13, 2025 at 3:13 pm
MirandaH
Ansys EmployeeHi, no need to sweep the coordinate system, just move the object. The object CS will move with the assigned object.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
