October 8, 2025 at 1:18 am
pgoudell
SubscriberI'm having an issue while running the HFSS IC>SI_interposer example. I'm pasting the errormessage below.
*Global - Messages
 [info] GRPC server running on port: 50052.Â
 [info] OpenGL Version: 4.5 (Compatibility Profile) Mesa 22.3.0
Interposer_SI (/opt/AnsysEM/v251/AnsysEM/Examples/HFSS 3D Layout/HFSS IC/)
 [warning] EDB is read only. Save or AutoSave can't be performed. (12:26:23 PM  Oct 07, 2025)
 HFSS-IC
  [info] cell count: 1, primitive count 406 (Top: 406), cell instance count: 0, primitive instance count: 406, text instance count: 0, instance array count: 0.
  [info] Mesh pre-processing took: 3.377sec  (12:28:44 PM  Oct 07, 2025)
  [info] Q3D pre-processing with filter floating geometries took: 0.769 sec (12:28:44 PM  Oct 07, 2025)
  [error] The solution folders could not be created; maybe due to illegal characters in design name or really long path exceeding system limit : /opt/AnsysEM/v251/AnsysEM/Examples/HFSS 3D Layout/HFSS IC/Interposer_SI.aedtresults/HFSS-IC/ (12:28:44 PM  Oct 07, 2025)
 [warning] EDB is read only. Save or AutoSave can't be performed. (12:28:44 PM  Oct 07, 2025)
preetham -
October 9, 2025 at 1:43 am
Atsuko Kikuchi
Ansys EmployeeThe error is caused by the project file being located in a folder that is not writable.Â
Please save the file to a writable folder (Menu:File > Save As) then analyze it.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
4052
1487
