Rocky periodic particle usage in a pipe
    • scabo
      Hi
      I am trying to simulate dilute micron-sized particles in a pipe with periodic condtions at inlet and outlet. Fluent DPM does not have periodic particles so i am planning to use Rocky. I was seeing a tutorial that has created a periodic domain. Can someone give an idea on whether is it possible to simulate dilute particle laden flow with periodic conditions for both particles and fluid in a 3d pipe? Can you refer to any material for this..thanks
      Have a look at Tutorial 4 and https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v252/en/dem_ug/set-simulation-parameters.html
    • scabo
      Hi-thanks. The link does not open-it requires Ansys account number, etc. Do you mean the section in Rocky user manual about Set simulation parameters pg 411? And the tutorial about SAG Mill?
      Not sure about page numbers, try https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v252/en/dem_ug/set-simulation-parameters.html  Yes to SAG Mill.
    • scabo
      The link does not open any specific page-so i think its not working-is this the page you are talking about?
      Did searching for "periodic" bring anything up?
    • scabo
      Yes i searched for 'periodic' in the user manual. It  has a page on domain settings like this
    • scabo
      and thisAre you talking about these?
      Try 3.2.6. Domain Settings Parameters
    • scabo
      In the Rocky user manual there is no 3.2.6 section. There is one 3.5.1.7 About Domain Settings Parameter. I think this is the one.
      There is in the 25R2 manual.... Hence me adding a link.
    • scabo
      Thanks-that link now works
Viewing 11 reply threads
