September 29, 2025 at 1:21 am
matheus.buvalovas
SubscriberHi!Â
I was using workbench fine till yesterday, now i encountered this error message
So i went in this forum to find a solution and I found out that I needed to add lines of command to a ansyslmd.ini file
So i added this lines of command and also deleted ansys from appdata/roaming and local.
And now when i try opening workbench I get stuck at this screen.
I have an academic license. -
October 1, 2025 at 3:50 pm
ANSYS_MMadore
Forum ModeratorAre others at your location able to access Ansys? Can you compare your ansyslmd.ini to their copy?
1461
