Electronics
Electronics
Error of Metal Fraction in Icepak Classic.
    • s-rathore
      I'm working on Icepak Classic. While running the parametric simulation. I'm facing the below error:
      "Error Computing metal fraction. Pleae check gridcut_log for details."
      Can anyone suggest how to remove this error!!
      Thank you in Advance!
    • Rabindra Paul
      Hi Rathore,
      Thanks for using the learning forum. It seems the model has PCB board and importing the trace. During the trace import process software needs to compute the metal fraction from the trace. The program is failing during that process. Is the model running for a single run - no parametric?  If so, you can turn the option 'do not recompute metal fraction' in the trace import panel. If it does not run without parametric option then there could be something wrong with the trace file.
      Hope this helps.
      Thanks
