Electronics
Electronics
Statistical Measure in Ansys AEDT using Python Scripting
    • se23mcme001
      I have calculated oscillator phase noise. Now i need to calculate Allan Variance using this phase noise data inside Ansys AEDT
      Now the issue is that the phase noise has  3000+ samples   and i need to calculate variance of it inside Ansys Software
      I have attached the formula for reference
    • Praneeth
      Bbp_moderator
      Thank you for reaching out to the Ansys learning forum.
      Please let us know the AEDT design type that you are using to help us serve you better.
      Best regards,
      Praneeth,
      Click here to join Electronics Community and build a network,
      Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
    • se23mcme001
      Hi, Thanks for the reply
      Here is the details, i hope it helps, let me know if anything else needed
      I am using ANSYS Circuit for oscillator analysis, I have calculated the oscillator frequency and Phase Noise,
      Now I want to calculate the allan variance usign the phase noise data
