August 8, 2025 at 6:39 pm
akumar44
SubscriberHi Everyone,
I can successfully run the Rocky software on the HPC using two Graphics Processing Units (GPUs). However, when I attempt to use more than two GPUs (three or four), the Rocky software fails to run on the HPC. I am unsure of the cause of this issue.
I have attached the commands used for both the two-GPU and the multi-GPU cases for your reference. Please let me know if you have a solution to this problem.
With this command, I am able to successfully run the Rocky software on the HPC using 2 GPUs:
module load ansys/25.1
Rocky --simulate "/gpfs_common/share03/electrospinning/akumar44/7_30_2025/K_SE_80MJ_CIO.rocky" >"/gpfs_common/share03/electrospinning/akumar44/7_30_2025/log01.txt" --resume=1 --use-gpu=1 --gpu-num=0 Â --gpu-num=1 Â --multi-gpu-slicing-direction=XWhen I used more than two GPUs and the simulation failed to run, I used the following command:
Rocky --simulate "/gpfs_common/share03/electrospinning/akumar44/7_30_2025/K_SE_80MJ_CIO.rocky" >"/gpfs_common/share03/electrospinning/akumar44/7_30_2025/log01.txt" --resume=1 --use-gpu=1 --gpu-num=0 Â --gpu-num=1 --gpu-num=2Â --gpu-num =3Â --multi-gpu-slicing-direction=X -
August 11, 2025 at 1:06 pm
Jackson Gomes
Ansys EmployeeHi akumar.
The error may be caused due to the syntax error in your multi-GPU command.
You wrote:
--gpu-num =3Â
(with a space before=
) maybe this is breaking the parsing and prevents Rocky from starting.Also ensure your HPC job actually allocates 3–4 GPUs on the same node.
August 11, 2025 at 8:55 pm
akumar44
SubscriberHi Jackson,
I appreciate your response.
I used the same node, and there was no space inÂ
--gpu-num=3
. The space was just a mistake when I wrote the question to you.Could you please let me know the actual reason why the Rocky software did not run with 3 or 4 GPUs? I was using the 2025R1 version of the Rocky software.
3797
1388
1188
1095
1015
