Error in generating modal neutral file (mnf) with workbench.
    • aisin3
      I need a modal neutral file (mnf) for rigid-flexible analysis in ADAMS, and I'd like to generate the mnf in workbench. I got a method from youtube on https://www.youtube.com/watch?v=-6asFnUr0ac&list=PLhb3ITFxzLNaL35lNzeickBVia7fdfkoF&index. The method involves two main steps:
      1. Set two remote points on the aeras which to be the rigid interfaces;
      2. Use APDL to generate mnf, the core command is:
      RESUME
      /units,si
      /SOLU
      nsel,s,node,,node1
      nsel,a,node,,node2
      adams,18
      ALLSEL
      /POST1
      where node1 and node2 represents the Pilot Node APDL name.
      Unfortunately,I didn't get "file.mnf" which I need, the content of "file0.err" is shown below:
       *** WARNING ***                         CP =       2.078   TIME= 226:10
       Element shape checking is currently inactive.  Issue SHPP,ON or
       SHPP,WARN to reactivate, if desired.
       *** WARNING ***                         CP =      19.547   TIME= 226:19
       The EMATWRITE,YES option does not currently support contact elements.
       EMATWRITE,NO is reset.
       *** WARNING ***                         CP =      19.609   TIME= 226:19
       The Distributed ANSYS solution does not support substructuring
       expansion pass analyses.  Distributed parallel processing will be
       deactivated for this solution.
       *** ERROR ***                           CP =      19.609   TIME= 226:19
       File genCMS.esav ( needed for element calculations ) does not exist.
       The step data was checked and there were errors found.
        Please check output or errors file ( C:UsersTao
       LVDesktop_ProjectScratchScr5997file.err ) for messages.
      So  I need guidance on this matter.
      Thank you very much!
    • Jannik99
      I have exactly the same problem. Do somebody find a solution?:)
    • BenjaminLan
      I have exactly the same problem...(๑ó﹏ò๑)
    • aryria
      your ansys version is old
      and tge solution is to try to write ADAMS, 19 or something else
      I can refer you to the article with url name below
      I hope to help you
      have good day
    • aryria
      by the way
      in some way ansys workbench cannot create .mnf file correctly the solution is to open Ansys mechanical APDL and open genCMS.db in it
      and in the Solution>Adams connection> Export to Adams create your own .mnf file with user name. and in this way your mnf file can create correctly without any disaster
      I hope to help you
Viewing 4 reply threads
  • The topic ‘Error in generating modal neutral file (mnf) with workbench.’ is closed to new replies.
