August 4, 2025 at 11:15 pm
Shyam Prasad V Atri
SubscriberI have a tank which has these dimensions
x [-0.7,0.7]
y[-0.5 0.5]
z[-0.5 0.5]
I am trying to run the simulation with 4gpu and i keep getting error in the simulation. This error is so generic and i dont know why it is causing
Error:QSocketNotifier: Can only be used with threads started with QThread
I have given the correct gpu slicing --multi-gpu-slicing-direction=X but still i get this error
Can anyone suggest why?
August 7, 2025 at 11:08 am
Lucas Bertollo Baggio
Ansys EmployeeHello,
does it work for single GPU?
August 7, 2025 at 11:10 am
Shyam Prasad V Atri
SubscriberIt works for single gpu and two GPU the moment I request 3 GPU or 4gpu the simulation keeps erroring outÂ
August 7, 2025 at 11:25 am
Ansys EmployeeRocky works for single-node only. Are all your GPUs in the same node?
August 7, 2025 at 11:26 am
Shyam Prasad V Atri
SubscriberYes they are all on same node and same hostÂ
August 7, 2025 at 11:30 am
Shyam Prasad V Atri
SubscriberAll 4gpus on same node and one computer. Still it errors outÂ
August 7, 2025 at 12:54 pm
Ansys EmployeeWould you give me more deatails about your case?
August 7, 2025 at 1:01 pm
Shyam Prasad V Atri
SubscriberIts a mixing tank of 1m diameter and 1m height. There is a top inlet pipe of 20cm and bottom outet pipe of 20cm in the x direction hence the total distance covered in x direction ranges from negative 0.7m to positive 0.7m. the pipe diameter is 10cm. I have about 700 sphero cylinder particles made of multiple elements (flexible one)
August 7, 2025 at 3:17 pm
Ansys EmployeeWhat GPUs are you using? Do you have license for using 4 GPUs?Â
It also seems like you have very few particles for using 4 GPUs.Â
August 7, 2025 at 4:34 pm
Shyam Prasad V Atri
SubscriberÂ
I gave 700 as an example… I have 70000 particles I want to add more than that too… I am using L40s or H100 or a100 gpu of University hpc cluster. I believe the universitys acadamic ansys license should allow the use of four gpus. i did not see any restrictionsÂ
August 8, 2025 at 3:48 pm
Shyam Prasad V Atri
SubscriberHello Lucas, Any idea why such a simulation is not working. Please let me know.
3597
1283
1107
1068
983
