May 10, 2020 at 11:44 pm
indra1994
SubscriberHi,
I am trying to define a multilinear stress-strain curve for each SOLID185 element in my ANSYS model. The stress-strain relationship is shown below. So far I have no idea how to define this multilinear relationship in ANSYS APDL 2019 R2. I tried to model it as Multilinear Isotropic Hardening but ANSYS throws error as the tangent slope can not be less than zero.
Can Anyone please help me with this?
May 15, 2020 at 8:23 pm
John Doyle
Ansys EmployeeKINH and MISO plasticity models do not support negative slopes as you have reported.
Make sure that your data input represents true-stress vs true strain. The slope might be positive after all.
If that is not the issue, there is another option. TB,NLISO,, will support a negative slope beyond yielding.
Keep in mind, the negative slope implies instability. Static analysis under a force based load will likely not converge if all the elements in the primary load path go totally plastic.
Hope this helps.
May 15, 2020 at 8:25 pm
indra1994
SubscriberThanks for your reply, It really helps.Â
- The topic ‘How to define multilinear stress-strain curve in ansys APDL’ is closed to new replies.
2999
970
857
761
599
