May 8, 2020 at 10:21 am
May 8, 2020 at 4:47 pm
Mike Rife
Ansys EmployeePrathmeshsanas2 Please right-click the Solution object and choose to open the solver files folder. Then screen-shot the contents and post it here. Next check the task manager, details looking first for ansys.exe does it exist? If so is it (or they) using a changing amount of cpu/ram/drive I/O ?Â
The most 'usual suspect' in this type of behavior are security type of applications (anti virus or malware, firewalls, etc) interfering with the proper start up of the solver.Â
Please also post a screen shot of the output listing in the Solution Information object. Â
May 9, 2020 at 7:35 am
Prathmeshsanas2
SubscriberThe Error file:-
/COM,ANSYS RELEASE 2019 R3Â Â Â Â Â Â Â Â Â Â BUILD 19.5Â Â Â Â Â UP20190805Â Â Â Â Â Â 12:48:45
 *** FATAL ***                          CP =      1.391  TIME= 12:48:47
 The version size limits( ELEMENTS )have been exceeded.                Â
 Contact your ANSYS support person for more information.              Â
 The above error is non-recoverable by ANSYS                           Â
 ANSYS run terminated by the indicated error                          Â
 Current data base saved if possible.                                 Â
the contents are:-
May 9, 2020 at 7:50 am
- The topic ‘solution is not proceeded’ is closed to new replies.
4673
1565
1386
1231
.jpg?width=690&upscale=false)
