Preprocessing
Preprocessing
How to generate a transfinite mesh (like in gmsh)
    • faradai2008
      I'm trying to generate a transfinite quad mesh for a composite model to be used in delamination analysis.
      Is it possible to generate a similar mesh to the one in the picture:
      This mesh was generated using gmsh.
      Thanks in advance
      Basem
    • Keyur Kanade
      yes, you can generate it in ansys meshing.
      please go through
      https://www.youtube.com/watch?v=nEOC8rDnnRo
      you may fine several videos on youtube on 2d meshing as well.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
  • The topic ‘How to generate a transfinite mesh (like in gmsh)’ is closed to new replies.
