July 9, 2025 at 3:34 pm
July 9, 2025 at 9:30 pm
Dennis Chen
Subscribertry using contact_automatic_surface_to_surface_offset and change the SAST and SBST with a negative number to represent the "search range". Interestingly enough, ansys workbench ls-dyna automatically outputs contact in this format and with the correct setting so this kind of problem doesn't happen. :)
July 10, 2025 at 2:24 am
b23040001
SubscriberThank you very much, Dennis! Let me try the way you suggested.
