May 1, 2020 at 6:33 am
shrestha1988
SubscriberHello, I want to simulate how the water flow inside a swimming pool when a water pump is placed inside the pool. The pump has been created by establishing the pool as a fluid domain and the pump is subtracted using Boolean. For the boundary conditions, I have used one side as velocity inlet and other as pressure outlet and used meshing as element order quadratic with 300mm size. I have used the pressure solver and the k-epsilon model. The result is attached below but it somehow does not look sensible. Please give me your suggestions on where I went wrong or how I should have done it better?
May 1, 2020 at 4:37 pm
Rahul Kumar
Ansys EmployeeHello,Â
As Ansys Employees, we will not be able to view any attached files. Can you please insert images instead so that we can better assist you?Â
Regards,Â
RahulÂ
May 2, 2020 at 5:08 am
May 2, 2020 at 5:17 am
shrestha1988
SubscriberAs you can see from the images, the flow is not symmetrical and iterations are not converging at all. I have run the simulations for 1000 iterations but the graph is still fluctuating. For the setup, i have used cylinder as a pump whose diameter is 0.3 mm and length 0.6 mm. The two sides act as velocity-inlet of 2m/s and pressure-outlet of 0 Pa. is 300 mm a large size for a pump flow? I have used element order quadratic, size 300 mm, adaptive sizing on, resolution 3, inflation as program controlled. I have used pressure solver, steady flow, viscous as k-epsilon and water as fluid domain. After this, I ran the iterations but the solution is not converging. Please advise where i went wrong in this and how do I get a more accurate solution.Â
thanks in advance -
June 7, 2020 at 5:33 am
shrestha1988
SubscriberHello, can anyone help me with this issue I am having with my project ?
- The topic ‘Pump water flow in a pool’ is closed to new replies.
4703
1565
1386
1242
