LS Dyna
LS Dyna
Question About Spring Model for Body-Ground Connection
    • a.purantagi
      I had a question regarding the spring model for a Body-to-Ground connection. I was working on a simple test case where I tried to model a spring connected to a ground and used N2=0 in the *ELEMENT_DISCRETE definition to represent the grounded end.
      However, I noticed that the spring doesn’t seem to attach to a remote or fixed point. Instead, it appears to connect back to the body itself, which isn’t the intended behaviour.
      Would you happen to have any suggestions or thoughts on what I might be missing or doing incorrectly?
      Appreciate your time and help!
      Looking forward to your response.
    • dchen25
      Hi, check your section and mat card.   I can't look at the docs right now (at work) but there are options that let you define a body to group spring.
