TAGGED: #fluent-#ansys, ansys-cfd, solver-initialization
June 14, 2025 at 9:24 am
Lumko
SubscriberGood day,Â
I want to simulate multiphase flows that is gravity-fed at the inlet and lifted from the sump by a submersible pump unsing Fluent. Â
However, my solution is refusing to initialise and it gives the following error:
Unassigned interface zones found. Flow is not initialized.
WARNING: Unassigned interface zone detected for interface discharge-pipe-wall-interface
WARNING: Unassigned interface zone detected for interface discharge-pipe-wall-interface.1
WARNING: Unassigned interface zone detected for interface inlet-pipe-wall-interface
kind regards,
LumkoÂ
June 16, 2025 at 6:18 am
abhishek.roy
Ansys EmployeeHi, create mesh interface using Domain > Interfaces > Mesh. Then, select the boundaries that make up the interfaces and click Create.Â
December 9, 2025 at 6:10 am
ssnigdha
Subscriberduring meshing, it auto create a conformal mesh in the interface. but in fluent, it wants to assign as an interface for two touching faces. I am facing a similar problem. did you solve it? please share
6625
1311
