TAGGED: addonmodule, Ansys Applications, modules, rocky-dem
June 6, 2025 at 6:31 pm
yhgeng
SubscriberHello there,
I tried to install particle_freeze_outside_region and sph_freeze_ouside_region modules to my Ansys Rocky, I moved them to Documents/Rocky/Modules, but when I restart Rocky and check the module section, I could not find those two modules.
Thank you
Yiaho -
June 11, 2025 at 8:41 pm
Lucas Bertollo Baggio
Ansys Employee-
June 12, 2025 at 3:53 pm
yhgeng
SubscriberHello Lucas,
I tried to ask our IT service to download the 25.1.2 version but there is only 202x.Rx downloads but not specific versions. And I tried to uninstall and install using the 2025 R1 installer, my Rocky was still 25.1.0.
Are the modules: "particle_freeze_outside_region", "particle_freeze_when_settled", and" sph_freeze_outside_region" backwards compatiable? Can I just change the folder name to 25.1.0 and use them?
Thank you
Yihao
June 13, 2025 at 5:08 pm
Ansys EmployeeYes, you could try, but there's no guarantee that it will work.
Ideally, you should uninstall the products, delete the v251 folder and install again with the automated installer. This way you will get Ansys Rocky 2025 R1.2.
Then download the module package (25.1.2).
best, Lucas
3236
1031
969
859
798
