May 22, 2025 at 4:00 pm
youssef.badran
SubscriberHello,
I am attempting to couple Ansys Rocky 2024 R2 with Ansys Fluent 2024 R2.Â
I am using the tutorial accessible via Rocky Interface → Help → Tutorial Workshops → 14. Tutorial - Fluidized Bed, which mentions that a mesh validation step occurs immediately after the
.cas
file import (section 14.2.14 in the tutorial). However, I encountered the following error: "Error during mesh validation."Could you please advise on the potential cause of this error?Â
May 28, 2025 at 1:45 pm
Lucas Bertollo Baggio
Ansys EmployeeHello,
Have you installed the Ansys Rocky additional package update?Â
This is the first thing you should try.Â
If installing this version does not work, I would recommend you uninstalling all Ansys products, deleting the v242 folder and reinstalling them (with this additional package for Rocky).
best regards,Â
Lucas
May 28, 2025 at 2:06 pm
youssef.badran
SubscriberThank you very much for your response.
May 29, 2025 at 3:54 pm
youssef.badran
SubscriberHello,
We have unpacked the additional package
ROCKY_ADDITIONAL_PACKAGE_2024R2.01_LINX64.zip
.Is it possible to specify its location from the ROCKY GUI in order to use it to solve my problem?
If not, could you please let me know what steps are required to enable its use?
Thank you. -
June 2, 2025 at 11:59 am
youssef.badran
SubscriberHello,
Is it possible to specify its location in the ROCKY GUI? If not, how can we enable its use?
June 2, 2025 at 1:47 pm
Ansys EmployeeOh, I am sorry. For Rocky 2024 R2 you don't need any extra package.Â
Please go through the following:Â
- uninstall all your Ansys Products and delete the v242 folder
- install Ansys Products again (including Fluent)
- install Ansys Rocky after installing Fluent with all the coupling checkboxes enabled
If you still get the error after this, upload some screenshots here to continue this discussion.Â
Best regards, Lucas
3190
1024
962
858
798
