April 24, 2020 at 7:42 am
bobd
SubscriberHi All,Â
I'm using a shear rate dependent vscosity for my simulations. My UDF work if I just take a constant value for the shear rate, but if I use a variable it gets this error: 'Â MPI Application rank 0 exited before MPI_Finalize() with status 2Â ' and then fluent closes.
I use a C_UDMI macro and I have enabled the memory in fluent, and I defined also the excute at he end in fluent.
April 24, 2020 at 10:49 am
Amine Ben Hadj Ali
Ansys EmployeeJust use the strain rate directly in the property UDF. Disable writing first as is not required.Â
- The topic ‘C_UDMI’ is closed to new replies.
1787
1387
1248
