vorticity-stream function
    • swa123
      hello
      can anyone explain me why vorticity-stream function is incorporated in CFD?
      What is the point of using it?
      apart from mathematical derivations I would like to know what it signifies when used in CFD:?
      regards
      swathi
    • Rahul Kumar
      The significance would mainly be that the pressure term in the governing equations can be dropped as a dependent variable and instead of solving the three PDE's as governing equations, it will be reduced to 2.
      Rahul
    • swa123
      that was a clean explanation!!
      thank you
      regards
      swathi
  • The topic ‘vorticity-stream function’ is closed to new replies.
