May 13, 2025 at 8:04 pm
siyangli1998
SubscriberHello,
I would like to create a coordinate system at a specific point on a component in Ansys Workbench Motion, but I don’t know how to create a reference point.
I tried creating reference points in Fusion 360 and in Ansys SpaceClaim, but when I import the model into Mechanical, the reference points disappear.
Can anyone help me with this? I’d really appreciate it. Thank you very much! -
May 14, 2025 at 8:38 am
Ashish Khemka
Forum ModeratorHello,
Please see if the following post is of any help: Ansys motion local coordinate orientation reset in post-processing
Ashish Khemka
Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers. -
May 14, 2025 at 3:35 pm
siyangli1998
SubscriberHello,thanks for your answer,
I tried to create a new coordinate system according to your instructions, but it doesn't seem to solve my problem. Let me describe my issue again: I want to establish a coordinate system at the position of the red point in the figure, so that I can select the correct rotation axis when creating a revolute joint for these two components in Mechanical. However, in my attempts, it seems that I can only select the center of mass coordinate system. Could you help me with this? Thank you!Â
May 14, 2025 at 3:56 pm
Ashish Khemka
The following link will guide you to create coordinate systems. If you have a vertex at the above locations or if you know the x,y and z locations of the indicated point then you can easily create the coordinate system:
Ashish Khemka
3134
1002
917
858
792
