TAGGED: 3d-maxwell-simulation, eddy-current, maxwell, temporary-files
May 6, 2025 at 1:25 pm
juhani.stenback
SubscriberHi,
After trying to run two Eddy current (3D) analyses simultaneously, I saw that Maxwell uses excessive amounts of disc space from my C drive even though I have set the temp file directory on a different drive. The allocated space is freed when the simulation ends or is aborted, so they seem to be temporary files only. Why is this, and how can I prevent this? What does the "override" box do?Â
May 7, 2025 at 3:31 pm
GLUO
Ansys EmployeeHi,
The results data file is saved in a folder next to your .aedt project file. Is your .aedt file also in C drive?
GL
Ansys Innovation Space
1283
1107
1068
978
