April 22, 2025 at 6:36 pm
joshua.e.kempenaar
SubscriberI have an existing SINDA/TSS model that has some nodes defined in SINDA and some nodes created by concap, but all the nodes are in the same submodel (ie MAIN). In TD, I created a logic object for the SINDA defined nodes. When I generate the INP file, the CC file ends up with two node blocks for the submodel ( MAIN), one from the logic object and one for the node generated from the geometry by TD. SINDA errors because there are two "HEADER NODE DATA, MAIN". Is there a way to make this work? or do I need to split it into two submodels? There are a lot of conductors as well so it'd be tedious.
++ERROR 38++ DUPLICATE OR INACTIVE MODEL NAME REFERENCED ON NODE HEADER INPUT.
April 23, 2025 at 2:10 pm
Doug Bell
Ansys EmployeeI am unable to replicate this behavior and have 3 header node data blocks for the same submodel in my test. I will reach out to you separately to get a sample of your inputs.
3044
971
863
858
792
