April 19, 2020 at 3:51 am
pkenealy
SubscriberHello,
I am having difficulty changing the scoping method for plotting stress results. I have made a named selection including all of the nodes I want to plot (excluding some stress artifacts at loads), but I am unable to change the scoping method for the plot from "Geometry selection, All bodies" to "Named selection". The box remains grayed out and does not have a drop down menu.
I would be grateful for any help with this.
Thanks,
Peter
April 19, 2020 at 12:10 pm
Aniket
Forum ModeratorSelect the single result object, right-click and click clear generated data and see if that enables the scoping properties. If not exit workbench and restart to make sure that have not opened the Mechanical in read-only mode.
-Aniket
How to show full resolution image
How to use Google to search within Ansys Student Community
- The topic ‘Remove certain nodes from stress plot in Workbench’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3912
1414
1256
1118
1015
