Electronics
Electronics
How to use simple calculating function on HFSS?
    • hyhaerong
      Hello, After I tried to rotate the 'plane' on hfss, realized I cannot rotate it like I did to an object. So, what I thought was adjust a normal vector in order to rotate the plane   However, have no idea how to use it exactly. What I've tried to do is set the normal vector of the plane by using circle equation. But, of course, it won't work like i expected...   Very aware of function in HFSS Is there any person who can help me with?
    • rtk
      In the attribute 'Normal', by 'root' you mean the square root function, you should give 'sqrt' instead of that. Also, 'x' is an intrinsic variable for HFSS. Try giving yet another variable name.
  • The topic ‘How to use simple calculating function on HFSS?’ is closed to new replies.
