Ansys 产品
Ansys 产品
Warning: No Cyclic constraint equations are not created for Thermal DOF’s(Temp)
    • loiteringfish
      I tried to create a Steady-State Thermal with Pre-Meshed Cyclic Region setting, but I found that I have no choice to operate this model with REAL CYCLIC. When I run this model, it can be sloved but the answer in two cyclic boundary regions are not matched with wach other, and there is a warning which writes [No Cyclic constraint equations are not created for Thermal DOF's(Temp)].
      I wonderd how can I calculate Thermal with Cyclic models correctly ( which means the cyclic regions are matched with each other ) , or it's not availble from the point of software functions? I found the explanation about Thermal constraint in Ansys website which said that [Cyclic symmetry solution does not work for elements that have thermal and hydrostatic pressure degrees of freedom.], you can see that on the pic and the link. https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v251/en/ans_cycsym/advcyclmnt.html
    • loiteringfish
      Please help me, or communication is also welcomed!
    • Huadong Sun
      According to the help documentation, Cyclic Region and Pre-Meshed Cyclic Region are supported for steady-state thermal analyses. However, in the post-processing stage, only the current individual sector's results can be viewed — the full model results are not available.
      If viewing the entire model’s results in post-processing is required, the full model must be built in the pre-processing stage, instead of using cyclic symmetry boundary conditions.
      https://ansyshelp.ansys.com/public/account/secured?returnurl=//Views/Secured/corp/v251/en/wb_sim/ds_cyclic_sym_considerations.html
      • loiteringfish
        Thanks for your reply. But the problem I encountered is not about the viewing, and I know that the view problem you mentioned can be solved in beta version. My question is about the base algorithm. I meshed the faces in two boundary regions through link function in ANSA, so the nodes in two boundary faces are one-to-one matched, but in my ANSYS Thermal answer, they are not one-to-one matched, there are differences between them. Even the differences are less than 1℃, this condition will also incur unreasonabl stress in boundarys. That is what confused me.
        According to the pic you provied, it shows that [the cyclic  symmetry solution in Mechanical APDL does not support elements with thermal DOFs], I think the meaning of this sentence is that the cyclic symmetry is ineffective in any thermal analyize? Or it can work by special settings?
    • Huadong Sun
      Could you please share a screenshot to help illustrate your issue?
  • 您必须登录才能回复此主题。
