April 11, 2025 at 8:34 pm
whiteten6
SubscriberHi,Â
I am working on a 2D model using fluent. The issue is that the optimization process is currently not functioning as expected. We identified the root cause: there is a persistent problem within Workbench where, after updating the geometry, the connection between the mesh and Fluent fails, resulting in a crash. Could anyone help us solve this? -
April 15, 2025 at 1:52 pm
Hemant Gurav
Bbp_moderatorÂ
Please ensure that all connections are correct and the case is properly set up. Verify that your solution runs successfully, as there might be an issue with its initialization or execution. Additionally, check your software versions and confirm that all files are in the same working directory.
