April 9, 2025 at 12:48 am
akumar44
SubscriberHi,
I want to export the steady-state data directly from Fluent to Rocky. I followed Chapter 17:Tutorial - Mixing Tee of rocky. I can't see the active menu of Rocky Export, which I found in the fluent menu tab. Just see the below figure
I don't know how to activate this menu in the fluent environment. Please help me activate it so that I can transfer the steady or transient data from Fluent to Rocky directly.
April 9, 2025 at 12:59 pm
April 9, 2025 at 1:01 pm
Lucas Bertollo Baggio
Ansys EmployeeOh, I saw in the other topic that you have followed this step.Â
Let's continue the discussion there,
April 9, 2025 at 3:28 pm
akumar44
SubscriberThank you for your information.
Step1 : First, I went to the Rocky software options menu. After installingÂ
fluent/rocky-export,refer to the image belowStep 2: I found the 'Rocky Export' menu in Fluent software—see the image below. Here, I got the Rocky Export menu active in Fluent software when I did not include case and data file in fluent software
Step3 : However, after importing theÂ
case.h5file into Fluent and running it for 1000 iterations, I navigated to the Rocky Export menu in Fluent, but found that it was not activated. Please see the image belowCan you please tell me how to export one-way data from Fluent to Rocky software? This was my problem.
5039
1749
1387
1248
