April 3, 2025 at 10:09 am
Jeremy Morgan
SubscriberI'm seeing some strange behaviour regarding Section views in a SpaceClaim Drawing sheet.
A Section view is not hiding the parts of the geometry above the section plane. See 1st screenshot.
If I rotate the view slightly, it's clearer (2nd screenshot). The part of the model shown by the red arrow should not be visible.
I can't see any option that I need to set to fix this; and it isn't behaviour that SC used to exhibit.
Any ideas?
April 4, 2025 at 1:16 pm
Charudatta Bandgar
SubscriberLet me check this, Jeremy. I will get back to you shortly.
Charudatta B
April 4, 2025 at 2:21 pm
Jeremy Morgan
Subscriber@Charudatta
Thanks for checking. I think the problem is on 2024 R2 version. I'm not seeing the problem in 2024 R1.
April 8, 2025 at 11:22 am
Jeremy Morgan
Did you get anywhere with this?
April 30, 2025 at 6:15 am
Charudatta Bandgar
SubscriberI have not been able to reproduce this with other files, I wonder if it is file specific.
- Add-in Error Excel
- Fileformats
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
- Inconsistent Script
4602
1510
1386
1209
