April 2, 2025 at 11:50 am
21315065
SubscriberI have created the mesh for my room and radiator and the mecshcheck shows no errors. For the simulation a radiator is attached to the wall however heat only seems to be emitting from the surface against the wall and is not transferring into the room. I have set up the heat transfer coeffiecent of the room and the radiator is set to a tempertature. Neither the room or radiator increase in heat. Any suggestions to why this may be?
April 2, 2025 at 12:13 pm
Forum ModeratorHow did you set the radiator temperature? What other boundary conditions are there? A cut plane of the mesh may be diagnostic.Â
April 2, 2025 at 4:06 pm
21315065
SubscriberÂ
I set the radiator as a temperature of 294K, the room walls were set to a free stream value of 287. There is no wall thicknesses applied to any walls. An warning has appeared when switching to solution:Â
Following expected zones were not found in the current mesh:
 radiator:119
 shelf:116
 Found Following new zones in the current mesh:
radiator:116
 shelf:119
Model Information is incompatible with incoming mesh.
Found some missing and new zones in the mesh. To make mesh compatible with settings, please visit "Match Zone Names" panel
(File->Recorded Mesh Operations->Edit Incoming Zones... -> Match Zone Names...).
April 2, 2025 at 4:12 pm
Forum ModeratorWhat exactly did you set as 294K? Radiator wall, cell zone, internal wall etc.Â
April 2, 2025 at 4:29 pm
21315065
SubscriberJust the Radiator wallÂ
April 3, 2025 at 9:55 am
Forum ModeratorOK, and a cutplane view of the mesh? I assume you've got wall & wall:shadow pairs around the radiator? Please post the image I asked for.Â
6550
1311
