March 24, 2025 at 10:50 am
March 24, 2025 at 12:37 pm
erik.kostson
Ansys EmployeeÂ
Hi
First I would close mechanical, and go to Workbench project schematic, and the Engineering data in your system and define some materials – then see if they show up and you can select them inside Mechanical.
If the above does not work see this:
https://innovationspace.ansys.com/knowledge/forums/topic/materials-not-visible-or-gray-area-around-materials-pop-up-menu-window/Finally if none of the above works, please contact your channel partner so they can look at your installation and help.
All the best
Erik
March 24, 2025 at 1:50 pm
michal.smalera
SubscriberI got the extra materials in Workbench.
I was working on a laptop with 2 external screens. I disconnected them, restarted Mechanical and Workbench and it works correctly now.
Thank you!
