Ansys Products
Ansys Products
Fluent-Rocky coupling
    • 2284579690
      My model is a fluidized bed. Particles are continuously generated from the bottom, and the water flow carries the particles from the bottom to the top.Rocky and Fluent are semi-resolved coupled, and the velocity field can be set and run. However, when Fluent opens the energy equation and Rocky sets the particle temperature, an error message is displayed.Is there anyone who can answer my question?
    • Lucas Bertollo Baggio
      the 2-way semi-resolved coupling between Ansys Rocky and Ansys Fluent does not support heat transfer yet, so the energy equation and thermal model should be turned off for the simulation to work.
      regards,
      Lucas
      • 2284579690
        好的,谢谢你
