Workbench Mechanical Update geometry Command Error
    • Omarwahba
      hi everyone
      i have a problem when i try to perform a non linear buckling analysis using updated geometry .
      i inserted the upgeom command in but i keep getting error "An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes."
      when i access the solution information i get the errors shown below
      *** ERROR ***                           CP =       0.516   TIME= 038:53
       Unable to open file F:MASTERSWIP2020-04-02Nonlinearbucklingtrial2don
       efile_filesdp0SYS-1MECHfile.rst.
       An error occurred while attempting to open the results file file.rst.
       No results file available.
       No displacements are currently in the database.  Use POST1 to load in
       the appropriate data set first.  The UPCOORD command is ignored.
      i checked the existence of the file.rst in shown path and it exist
      the command line is as attached
    • Afneer Raghon
      Did you solve your problem Omar? I'm also getting this error.n
  • The topic ‘Workbench Mechanical Update geometry Command Error’ is closed to new replies.
