April 2, 2020 at 4:28 pm
Yangkyu
SubscriberHello I am running thermal-structural analysis with different plate thickness (Ansys workbench)
Specifically, there are 4 stacked plates. The top plate thickness are changing from 10 to 100 micron. When I run this simulation with each step in the Model, I got the results. But, when I did parametric study, I got error message ‘update of geometry component in steady state thermal for design point did not mark container as updated (final state is modified)’. Please find attached image.
Could you please help me to figure it out? -
April 6, 2020 at 10:18 am
Aniket
Forum ModeratorI am sorry Ansys Employees can not download the images in the attachements from thes student community.
Which version are you using?
Are you saying that if you manually update each design point it updates successfully but not when you use "Update All Design Points" button?
-Aniket
- The topic ‘Update of the geometry component in design point did not mark container’ is closed to new replies.
Ansys Innovation Space
1333
1173
1090
1014
