February 26, 2025 at 4:06 pm
zhou333708124
SubscriberI set 2 UDFs in my case
One is "DEFINE_EXECUTE_ON_LOADING" type, this UDF can be auto run and it execute correctly.
The other is "DEFINE_EXECUTE_AT_END" type, this UDF need to be hooked and it cannot execute in calculation process.
I check the "start_coupled.jou" and "fluent.log" written by RockyDEM, and I found Rocky set its own UDF by "/define/user-defined/function-hooks/execute-at-end "exchange_rocky_fluent_coupling_data::rocky_fluent_coupling" "inject_remove_particles::rocky_fluent_coupling" """
This command hooks those two UDFs to execute-at-end, my UDF has been replaced or just not get hooked, so I cannot use UDFs that need hooking in coupling. This command is execute automaticly by Rocky.
As the Rocky coupling start, there are nothing I can do to pause the process or exchange the files, so if there are anyway to hook my UDFs automaticly?
March 7, 2025 at 12:12 pm
Jackson Gomes
Ansys EmployeeHi Zhou,
Rocky automatically sets its own UDFs in execute-at-end, replacing yours. To work around this:
- Use a different hook, like DEFINE_ADJUST.
- Modify
start_coupled.joubefore execution to add your UDF. - Append your UDF to the same hook manually if possible.
March 10, 2025 at 7:04 am
zhou333708124
SubscriberÂ
Thanks Jackson.
DEFINE_ADJUST cannot be hooked normally. As you can see, execute-at-end, initialization and adjust are all replaced.
But some of DEFINE_PROFILE UDFs can be executed.
To modify start_coupled.jou or hook my UDF manually have the same problem that I can’t pause the process, the calculation is automaticlly execute by Rocky, and if I change the .jou file the process will be shut down.
If there are any option for user to pause the process and adjust the setting manually?
Best wish for you
March 12, 2025 at 6:08 pm
Jackson Gomes
Ansys EmployeeDear Zhou,
Which Rocky version are you using? Also, can you check yourÂ
.casfile in a text editor like Notepad++ and look forudf/execute-at-end-fcns,udf/init-fcns, orudf/adjust-fcns? If Rocky is replacing everything, have you tried running Fluent in interactive mode before starting the coupling?
6795
1343
1152
