March 31, 2020 at 9:29 pm
EugenioMuttio
SubscriberHello everyone,
I have this case study in which I want to test several meshes to this "plate with a hole model". I want to impose a stress state on the boundaries which I obtain by tabular information, but I only managed to impose the normal stress.Â
Is there a way to impose stress components (X, Y) in the same way using tabular information?
March 31, 2020 at 11:21 pm
Wenlong
Ansys EmployeeHi,
I guess "line pressure" can work as the stress_xx, and pressure can work as stress_yy in your case? (Reference for line pressure:Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/wb_sim/ds_Line_Pressure_Loads.html)
Wenlong
Useful Links
- How to access Ansys Online Help Document
- How to show full resolution image
- How to use Google to search within Ansys Student Community
April 1, 2020 at 9:31 am
EugenioMuttio
SubscriberHello Wenlong,
Thank you very much for your reply, line pressure is a good idea as I need to apply shear stress, but as my problem is 2D I guess I can't use this option. Do you know if there is a way to use it for 2D cases?
Eugenio
April 1, 2020 at 2:49 pm
Wenlong
Ansys EmployeeHi Eugenio,
Yes, line pressure is only available in 3D. The only way I can think of is to do an integration and convert stress to force, then apply nodal force to the top edge. Unlike force, nodal force allows you to define space-dependent magnitude.
Wenlong
April 8, 2020 at 1:27 pm
EugenioMuttio
SubscriberThank you Wenlong,
At the end, I decided to use a displacement field for this problem as the line pressure is not defined in 2D. But if I will model in 3D, I will use it.
- The topic ‘Stress function over an edge’ is closed to new replies.
4924
1613
1386
1242
