March 26, 2020 at 2:25 pm
matahari
SubscriberHello everyone,
I would like to delete some features of an imported geometry, but it's imported as one part/one body. How do I go about this?
March 26, 2020 at 3:26 pm
peteroznewman
SubscriberRight mouse click on Geometry and select Edit in SpaceClaim (prefered) or Edit in DesignModeler (not preferred). In SpaceClaim, you can generally select the feature faces you want to remove and then hit the Delete key on the keyboard.
If you have spent some time building a model, you might have to repair some load or constraint scopes after you open the Model.
March 26, 2020 at 9:51 pm
matahari
SubscriberIt worked great, thank you.
March 27, 2020 at 4:37 am
Keyur Kanade
Ansys EmployeeAs it worked, can you please mark this as 'Is Solution' to help others on community.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
- The topic ‘Simplifying imported geometry’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
4137
1487
1318
1164
