3D Design
3D Design
Creating a construction line on a body to apply force
    • yazk
      Hello dear friends,
      I have imported a CAD model to ANSYS Workbench from Solidworks for a static structural analysis. I would like to apply a line force to the body as shown in the picture below. However, I am not sure how to make the construction line to apply my force or any other way that works.
      Thank you for your help.
      What is the source of this force?  If it is the weight of the pipe and the fluid inside, you can add a line body or a solid body on the inside to represent the fluid and then turn on Gravity.
    • yazk
      Hi Peter,
      Thank you for your response. Actually the line is in the outer surface of the pipe and representing the line contact of the pipe - clamp and as if the clamp apply a contact load force to the pipe. Also, I made a line body in SpaceClaim, however it does not show the line in the Ansys workbench.
      Thank you,
    • Aniket Chavan
      Use Project tool in Intersect group of tools on the Design ribbon to take an imprint of the curve on the Solid.
    • yazk
      Thank you Aniket for your response. That works well.
      Best,
    • Aniket Chavan
      please mark the post as solution if it answered your question.
Viewing 5 reply threads
  • The topic ‘Creating a construction line on a body to apply force’ is closed to new replies.
