March 13, 2020 at 1:21 pm
Balakumaran
SubscriberHi !
I am beginner of CFD ,I should to cool one rod (which is 18 mm dia ,54 mm heigh and 80°C continuosly generates) around forced convection Dia 20 mm ,height 54 mm (water inlet = 30 °C ,mass flow rate = 3*10^-4 kg/s ,water outlet = 40°C) .what are the boundary conditions steps need to be consider.
Could you please tell me the boundary conditions steps to cool this rod.
Thanks lot ! -
March 13, 2020 at 6:25 pm
DrAmine
Ansys EmployeeTransient Solver
Rod modelled as resolved solid zone
Fluid Zone with boussinesq approximation for density or temperature density. Account for gravity effects.
Opening or sides as pressure boundaries. If forced convection you probably have a forced inflow. Incorporate it as velocity inlet or mass flow inlet or pressure inlet.
Start looking in to the standard Fluent tutorials.
- The topic ‘Forced convection’ is closed to new replies.
1311
