March 11, 2020 at 6:27 pm
Swadesh
SubscriberHello,
Can anyone please suggest how to design a transistor from datasheet in Ansys circuit. I have some tutorial in ADS but for co-simulation purpose, I need to do everything in Ansys. Any suggestion, document or guidance would be very helpful.
Swadesh
March 12, 2020 at 5:26 pm
Charlotte Blair
Ansys EmployeeTake a look at ANSYS Circuit Overview in our help document
for transistor specific information please go here
March 13, 2020 at 5:15 am
Swadesh
SubscriberHi,
Thank you. However, I can't access the link. Do I need to have any access for that link to see?
March 13, 2020 at 2:00 pm
Charlotte Blair
Ansys EmployeeThe link is to our online Help documentation which has the most current documentation. Please check with your institution about online guidelines. We also offer installed Help documentation that is current at the time of software installation. To access the pdfs of the Help documents go to Help on the AEDT Toolbar
Select Help > Circuit Pdfs > Circuit Help
There is a very good example to try as wellÂ
Circuit Help > Nexxim Design Examples > DC-IV Characteristics Transistor Example
as well as the examples in the Getting Started Guide
March 18, 2020 at 6:34 am
Swadesh
SubscriberHello,
@cblair Thank you very much. This is my understanding below. If wrong please correct me.
1. I can edit/modify generate DC-IV curve for 23 supported model.
2. Based on my datasheet, I can modify parameter and substrate (Rogers) type to compare the IV curve like datasheet.
3. After modifying the datasheet the model i get, I can use that as spice model for my co-simulation, right?
4. Besides, I can also extract S parameter from this.
5. For linear analysis, it would likely be S-parameters, and for non linear, a spice model.right?
6. How can I save the spice model and use that for future simulation?
7. For spice model, do I need to keep the full circuit model always? (e.g. inductor, resistor....) or I can add delete component based on my required circuit combination?
Thanks
Swadesh
March 19, 2020 at 5:44 pm
Swadesh
SubscriberHi,
Another thing, I was looking for a HEMT transistor. It seems that is not listed in Ansys right now. Is there any way that I can design that or any future version can be compatible with that?
Thanks
Swadesh
- The topic ‘Transistor Model in Ansys circuit from datasheet’ is closed to new replies.
6324
