Photonics
Photonics
Running FDTD simulations on Linux
    • edith.hartmann
      I am trying to run simulations on linux (ubuntu 20.04.6 LTS), but I have issues when launching the GUI interface of Lumerical. Below is the error message I get after trying to open a simulation file with the GUI:
      e_hartmann@speckle:~$ ./tools/v242/bin/fdtd-solutions
      Messages file /ansys_inc/shared_files/licensing/language/en-us/ansysli_msgs.xml does not exist.
      ./tools/v242/bin/fdtd-solutions: line 8: 1980362 Segmentation fault (core dumped) $FDTD_BIN_DIR/fdtd-solutions-app "$@"
      I also tried to open and launch a simulation using the terminal only: ./tools/v242/bin/fdtd-solutions -nw -run simulations/FDTD_run.lsf simulations/nanofin_test_FDTD_2.fsp
      By doing that I don't get any error message but the simulation doesn't seem to run (no log file created).
      Thank you for your help!
      Edith Hartmann
    • Lito
      Hi Edith,
      We have the following:
      (1) Messages file /ansys_inc/shared_files/licensing/language/en-us/ansysli_msgs.xml does not exist.
      You can ignore this message – this will not prevent opening or running the application. To remove this notice, create a blank XML (ansysli_msgs.xml) file in the said folder.
      (2) ./tools/v242/bin/fdtd-solutions: line 8: 1980362 Segmentation fault (core dumped) $FDTD_BIN_DIR/fdtd-solutions-app "$@"
      This segmentation fault / core dump error is typically due to missing or incompatible system/graphics/OpenGL libraries. Make sure that you are connecting to the Ubuntu machine via a GUI connection e.g. VNC, X11forwarding and the Ubuntu machine has a /Desktop environment, e.g. Gnome or Mate. We have the following KB for more information.
      (3) ./tools/v242/bin/fdtd-solutions -nw -run simulations/FDTD_run.lsf simulations/nanofin_test_FDTD_2.fsp
      The above command runs the FDTD_run.lsf and opens/uses the nanofin_test_FDTD_2.fsp indicated in the command. If you do not have the required libraries and support for OpenGL 3.2 and higher, this will result in the same segmentation fault / core dump error. Its the same as running the Lumerical FDTD CAD/IDE.
      /tools/v242/bin/fdtd-solutions &
      Run FDTD simulation files directly from the command prompt using the engine/solver executable/binary not the CAD/IDE. This process does not require a GUI connection to the Linux machine (headless systems). Starting with 2024 R1, we do not bundle any MPI in Linux. See the KB and examples below for more information:
      ## example below runs the simulation.fsp file without MPI using 32 threads/logical processer on the local machine
      /tools/v242/bin/fdtd-engine -t 32 /pathto/simulationfile.fsp
      ## example running OpenMPI with 32 processes, 1 process on 1 thread/logical processor on the local machine
      /pathto/openmpi/bin/mpiexec -n 32 /tools/v242/bin/fdtd-engine-ompi-lcl -t 1 -logall /pathto/simulationfile.fsp
      Let me know if you have any questions or concerns.
    • edith.hartmann
      Hi Lito,
      Thank your for your response, it was very usefull!
      Is there a way to run a parameter sweep or a script directly from the command prompt, without requiring a GUI connection ? I was only able to run a simple simulation file .fsp with the "fdtd-engine" command but I would be interested by running parameter sweeps.
      Edith Hartmann
    • Lito
      @edith.hartmann,
      You are welcome.
      (1) Please see the KB >> Running parameter sweeps without the CAD – Ansys Optics
      • Where save the parameter sweeps and run them outside the GUI using the “fdtd-engine” directly from the terminal.
      (2) You can either run them sequentially or concurrently – see KB below for more information.
      Let us know if you have any questions or other concerns.
