March 5, 2020 at 9:49 pm
ATournilhac
SubscriberHello,
IÂ 've created a Synchronous Machine model from Rmxprt and everythings works properly. But when I want to switch to the full machine (Maxwell propose to simulate just symetrical fraction of the machine), each parameter is correctly duplicate except damper bars.
This is really weird, Is anyone had the same problem ?
Thanks
March 14, 2020 at 4:34 am
Navya Chode
Forum ModeratorHi,
Before you analyse the RMxprt model, go to RMxprt > Design settings > User Defined Data > Check Enable
In the text window type "Fractions 1" with out quotation marks (capital F).
Then Analyse the RMxprt model and create the Maxwell model by right mouse click on Analyse > Create Maxwell design.
This should generate the full machine Maxwell modelÂ
February 2, 2021 at 7:43 am
hamid1
SubscriberThanksn
- The topic ‘Maxwell2D Model from RMxprt – Issue when swiching fraction to 1’ is closed to new replies.
1311
