Fluent Convergence condition does not stop the iteration
    • jeong
      If convergence condtion is set as "All the conditions are met", then even after console shows "report defition is converged" for all the criterias active, iteration does not stop.
      If condition is set as "Any condition is Met", then it works properly and stops iteration. How to solve this problem?
    • DrAmine
      Convergence by residual active,?
    • jeong
      It works fine with residual convergence active. Thanks!
  • The topic ‘Fluent Convergence condition does not stop the iteration’ is closed to new replies.
